Done a bit of diagnosis on the S8 I picked up a couple of weeks ago. Looks like its going to take more fixing than I've got time to give it, but just before i move it on, thought I'd run past them that know more about the bonnet contents than your truely
1) Cylinder 6 seems to be completely ineffective. Engine performs the same with the coil pack connected or not
2) Wiring to Cylinder 6 seems rock solid, all wires trace back to where they should.
3) Cylinder misfires on both LPG and petrol - So not an injector issue
4) Swopped coil packs and plugs - no difference
5) No faults logged in ECU - Suggests not an electrical fault
6) Compression is significantly lower on cylinder 6 than the others
So, I guess I'm looking at either a sticky valve, or failed piston seal ?
One thing that really interests me, is that the plugs from cylinder 6 came out wet, and smelling strongly of petrol..... Surely, even with poor compression, the petrol, spart plug and air would still burn up the fuel, just not provide any useful power from it ?
Anyone got any troubleshooting tips that dont involve removing the cylinder head, or using an expensive camera I dont own.... If its valves, I'd be slightly tempted to fix as it could be done in situ, piston probs is a bit more major....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
