Old 21st April 2012, 09:17 PM
The S8 alluminium mirrors are solid and annodised. I have removed the annodisiation on a set and it took several hours with 80 grit flap wheels. It then took far longer to repolish the alluminim to a mirror finish, acid etch and lacquer. If a stone strike has pierced the anodising then corrosion will set in and there is no way to get the pittting out and maintain the anodised coat. Once the annodised coat is removed it is like a polished wheel rim. You need to keep doing it.
I'm sure I have put some photos on here somewhere.
Here.
HTH
CtL
