View Single Post
Old 21st April 2012, 11:22 PM
Jake242's Avatar
Jake242 Jake242 is offline
Do you need to go as course as 80 even 120, this must put horrendous scores on the ally and will be a nightmare to remove the scoring.
Try starting with the 240
I had one chip(the one that looked like there was plastic underneath) it was like 1/2 mm.... went through the anodized layer, so I had to take the entire anodized layer off... with 240 this would take 15 hours alone:-)
The last picture I posted shows a finish that has not been polished(as I have no polishing machine)... I recon I can finish it down so no visible scratches is there... then send it to an anodizing place that can chemical clean and polish it and then anodize it, thats the plan anyways.
I will update once everything is done.
Cheers for the good advise all around
/Jake
Audi A8 4.2 quattro D2 94' - THE CARRIAGE
Audi A4 1.6 B5 95' - THE LADY IN RED
Opel Kadett 1,2 C 77' - THE CASKET
