i dont think you can code it that way, be great if you could.
there is someone on ebay selling a fitting service using much the same camera, to do this he also fits a device at the front which hooks up to the MMi and also gives you several other inputs as well as the reverse camera. you would have to run the camera lead from under glove box to rear though (unit costs around £149)
also Guy, have you got a 2 screw number plate light or the single screw joby?
