Old 30th April 2012, 02:09 PM
graynada graynada is offline
Do you have a solar roof? If I remember correctly there is a relay that switches over from the normal 12v supply to the power produced by the sun roof. If this relay was stuck in the normal supply position when the ignition is turned off it might, be running off the battery. I haven't got any wiring diagrams with me to check that theory out.
