Just to close this thread, the problem went away and didn't return before I destroyed the engine.
However, while fitting the new engine at the first fire up I had the same symptoms and it was due to fuel starvation and it threw up the same code!
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
But not the Cylinder 5 code.
So check your fuel if you get this code as well.
