Old 5th May 2012, 06:16 AM
you need vcsd to change the consumption, this is how, you also need it to enable the hidden menu
Correct Consumption in DIS program
[17 - Instruments] [Adaptation - 10] -> Channel 3 change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9.3 l/100 km.
Real: 9.8 l/100 km. (100 * 9.8 / 9.3 = 105.38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95.83)
Channel 3 will be changed from 100 to 96
