Old 7th May 2012, 03:33 PM
47p2's Avatar
47p2 47p2 is offline
I would say it's definitely not a bearing.
The piston. in the caliper will be corroded, if you can obtain new seals than remove the pistons and carefully clean the rust off them with wet & dry and rebuild. It doesn't always work as it depends on how bad they are corroded.
Easier option is to fit new calipers cost is somewhere in the region of £65 to £80 to £149 each depending on type Link
Nite Blue 3.0L SE Quattro
