Old 21st May 2012, 11:51 AM
Im not sure that there is....
Its such a stupidly simple module - It would work on any car.
There are inputs for the stalk - On/off/set/resume etc.
Speed pulse input
Then an output which it uses to drive the sucker pump that pulls the throttle in.
You press set, and all it does is memorise how many speed pulses / sec you want to achieve. If it falls below that, it puts on the sucker pump to pull the throttle in a bit more....
