Old 12th May 2009, 04:32 PM
To remove the rear seats (non ISOFIX) there are 2 Philips screws under the rear seat about where your calfs would be, buried in the carpet. make sure you don't switch on the ignition after you remove the seats as you'll throw a fault on the airbags as they are wired in and you will be disconnecting them.
Once the seat is out there are 2 screws at the bottom of the seat back. Undo those and you lift the back upwards and out but release the airbag cabling first.
With the seat out look behind the trim and you'll see some fasteners which you need to undo. then follow the trim to the section between the doors which needs to be removed first and then you can remove the door bottom trim. I'll try and find a picture a bit later.
