Old 5th June 2012, 12:26 PM
RanjS8 RanjS8 is offline
Default Hex bolts not the torx bolts
Turns out the torx bolts hold the upper part of the manifold to the lower part. To remove the intake manifold you have to undo the hex bolts...there are 7 each side and the intake manifold pretty much drops off.
There are vaccuum pipes you have to detach and the fuel pipes...but other than this comes off fairly easy.
