View Single Post
Old 12th June 2012, 11:08 AM
Originally Posted by jeropz View Post
Hi,
I have an issue wih my car and I think this is the correct place to get an answer.
The problem is that the audible turn signal indicator doesnīt work properly. The tick-tock sound is very very low and I canīt even hear it.
Sometimes I forget to disconnect the blinker and I drive miles and miles with the blinker lighting. I,ve changed the relay and that wasnīt the problem.
Can anybody tell me how to fix this?
Thanks in advance,
best regards.
The easiest solution I know for this is to have a look at your dash more often, you should see a green flashing arrow that corresponds with the direction indicator. There are also more useful gadgets down there too, like speed, rpm, temp and fuel left in tank indicators.
