You have to get behind the side linings in the boot and then you can see the tubes going into a rubber housing. The tubes pull out and you can get a something poked down, but up will be more tricky. I have posted a picture on here somewhere of one side.
I have a faint recollection from when I was trying to dry out my eight that there can be an issue with a 'drip tray' that is supposed to come into position along the back edge of the sunroof when it closes. The idea is that this tray will catch water getting past the seal on the back edge of the sunroof, and then drain that water to either side and eventually to the drains. If my memory serves me correctly I read that there are some plastic bits that can break that stop this coming back in to position on closing the sunroof. I'm guessing depending on what angle you car was parked it may be possible that water coming through the rear of the sunroof eventually built up and came out as you described. I think if you put the sunroof on tilt you can see said tray.
