Old 29th June 2012, 05:56 AM
Looks like simple fix- install extra injector in intake to spray some fuel in to clean up build-up, maybe a bit smaller then stock injector and wire it to fire together with one of main injectors. 1 extra injector for 8 cylinder car would be 12.5% extra fuel which would be near the limit of adaption range but if you put smaller injector ECU should be able to adapt to extra fuel.
