Old 3rd July 2012, 07:42 AM
71camaro 71camaro is offline
IIRC it was over the entire area. And (cue more jokes about failing faculties) I think there was an inner lens (???) that was plastic and it was that that the film was applied to
Ah, that makes sense. That inner lens is the one that silverd2 referenced in the other thread. It covers the main beam and nothing else. That would explain why only a portion of the lamp looks darker in photographs. I'd imagine the film he used was the same as is generally used as a window tint. But to be clear, to the best of your recollection, it was not the outer lens that was darkened? If that is correct, I see in my head how everything should go.
