BTW in case you aren't aware of them, here are some shortcuts and hints/tips
in menu mode the menu icons are 'mapped' to the equivalent number key on the keypad 9e.g. top left is mapped to 1, bottom right to # and you can just press the relevant key to select an icon.
you can arrange any icon to anywhere in the menu structure, so put most commonly used apps on the front screen or on easily remembered key press sequences ( e.g. TomTom on mine is 5-5 )
if you press and hold the right and soft key it enables voice commands so you can say names etc and it will autodial or even activate functions ( e.g. saying Bluetooth turns it on and off. you may need to reset teh voice dial function first.)
Press and holding the left soft key "reads" out any new text messages on some models.
To quickly switch between silent and general profiles hold the # key
A quick press of the power key brings up a list of different profiles to choose from.
Hold the menu key for a list of apps currently running. select one to switch to it or press the C key to close it down.
If you set the "log" function to 10 days instead of 30 it will speed up the device overall!
I'll add more when I think of them!
