I think it depends on how long you're likely to be waiting for. If its a large junction where the wait is longer then I just knock mine into neutral and put the handbrake on, if you put it into park then it alarms the car behind when your reversing lights flash on as you go through reverse to get there!
If it's just a short while then I keep my foot on the brake for a few secs and then pull off as normal
If the clutches are going in the auto box then it will slip in a gear (or more) and the gearbox will go into limp mode and all the gear indicator lights on the dash binnacle will turn red.
