There are lots of clusters representing different eras of A8 evolution. You need the one with the same part number. If part number is different you should understand what you are doing. I don't have spare cluster at the moment. What I can suggest is to remove your cluster, read part number from sticker on the back, put it back, source temporary off eBay, code it with same coding number... well, you've got the idea
