Old 4th September 2012, 10:35 PM
RanjS8 RanjS8 is offline
Default fuses
Do a continuity test across all your fuses in the fuse box....It might be a not so obvious fuse....Failling that I would check the wiring diagrams in elsawin and see if you can trace the wire back....not an easy task at all....
good luck
ps taking the glove box off is easy really...just three bolts as shown above...putting it back now I have to say it is the one job I absolutely hate on this car....lining up the holes, holding the glove box up and getting the bolts in....such an awkward job hate it every time!!!!!!!!!!!!!!
