View Single Post
Old 10th September 2012, 06:11 PM
I agree with ainarssems. Don't worry about it until its an issue. When it is an issue, go down the brute force root. Make sure you use a 6 sided plug spanner for maximum grip and a long breaker bar to exert torque slowly. If it snaps, get that cylinder to top dead centre on the compression Stroke (valves both closed) And get a piece of wood dowel the same size as the plug housing and drill a 4mm hole to start with in it with a pillar drill. You now have you drill guide. Measure the amount of plug left in the hole, mark you drill bit so you don't drill to far ( preferably not as far as the electrode) and steadily increase the size of the bit until about 10mm, then try a stud extractor. If that fails, continue drilling until you drill out the plug and the heli coil blow out any swarfe, vacume out the swarf, then blow out the swarfe and reasemble.
