Old 18th September 2012, 10:16 AM
I've just fitted (it's a long overdue job) LED numberplate lights - literally a few minutes ago.
The old festoon bulbs, 1998 originals, were "interesting" - I think "smoked" would be the best description .
Can't wait to see how the new LED's look at night in comparison as they already look a lot brighter, and I only used some oldish spares I had lying around - what I'd describe as the "bubble" type LED's (4 per unit in these) not the newer brighter SMD type.
I also took the bulb holders out completely and cleaned them. I think "over-engineered" describes them pretty well. Most cars have plastic mouldings that just clip in, these have a solid metal baseplate held in by a pair of 10mm hex-head bolts. The bolt heads looked corroded and I was concerned the whole bolt might be rotted, but they were fine it was mostly dirt and the threads were clean and shiny - I put a drop of oil on each of course before refixing.
The only bulbs left that "could" be dealt with now are the front sidelights, but they are a total swine to get at with the PF Xenon setup so I'll leave them alone while they're working OK. I never drive on just sidelights anyway.
