Old 18th September 2012, 10:37 AM
Facelift = no prewiring anywhere, for anything
Autodim wiring from memory has power and ground in, a reverse feed in (so it lightens up when you select reverse) and then it has outputs that can drive the exterior autodim mirrors....
So, worst case power and ground would get it working - It depends how much of a perfectionist you are as to whether you run the reverse feed too
