Originally Posted by Tony82
Hi, usual sort of thing, clunking, slipping in and out of gear at low speed, engine 'vamping' when decelerating (torque converter I think), and dreadful mpg - the engine seems to be fighting the transmission - all bad, and suggest A clutch is going, and messing the whole transmission (for instance it reverses at 20 mph - v disturbing!).
My problem is finding someone to do it - esp the cam belt and associated rattles from the front of the engine!
Petty as it is a fine car - and I want to get it fixed!
Any thoughts on who may be able to help? (Unit 20 (?) seems to get a good reference but is miles away from me!)
Thanks
Almost sounds like it could be just a bit low on fluid..... If you're actually getting into gear, but the torque convertor is slipping, then its quite possible, and a simple top up would be a very cheap fix.
I would always use a ZF specialist gearbox place, rather than a regular servicing garage for TLC on a gearbox. They will usually know far more about symptoms and remedies...
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
