the battery meter is not a good indicator, it seems to be more battery condition than power, mine is draining without anything switched on, although only at a small constant amount. and often doesnt go up again, even on a 200 mile drive
I had 5570 too, but not every update had been done, the Audi tech who updated mine believed that the problem hadnt been resolved as my Radio was on the latest software, but i believe its not only the radio software at fault
once the fault occurs you defo need to update the battery serial with vagcom or the car beieves your battery is on its way out
touch wood the car has now been ok since the update on friday.
