Old 6th June 2009, 03:01 PM
It used to be scary, but I think its been dont enough times now....
If you already have a facelift car with a double din sat nav, its pretty easy.
http://www.kufatec.de/shop/index.php...aad34686a4d712 -
Kufatec will provide you with a cable loom for about £40 that will adapt the existing audio unit to the RNS-E multi block connectors which are significantly different - the £40 is worth it. They also do a convertor for the RF aerial and GPS aerial connections which makes life easy.
Physically, neither the A6 nor the A4 unit will fit perfecty. The A6 will be slightyl too wide, and the A4 one is slightly too narrow (mm or so, barely noticable) and too tall, but can be shaved down.
Expect to pay 50% extra for an A6 unit over the A4 ones though, hence the temptation to go with the A4 unit and 'make it fit'...
