I have started to install the bluetooth unit and have got stuck very early on - I will be missing something very obvious.
I have the cill trim removed, the trim over the bolts at the base of the seat, and the carpet lifted around the air vent.
Where I am stuck is removing the passenger seat. I have found 2 black T45 bolts that do not let me remove the seat as these are too high up. I have also found 6 T40 bolts that look like they attach the seat to the top of the rail (under the small plastic trim). Is it these 6 bolts that need removing as they are very tight and I wanted to be sure first as I cannot see any T50 bolts. Removing these bolts will leave the rail in place assuming that these are the correct bolts.
Can you point me in the right direction?
Thanks
