Old 16th November 2012, 03:39 PM
Mutley Mutley is offline
It should still go up and down.... Assuming you're stationary. If you're above a certain speed, it's always at the lowest level, though dampers should change.
hmmm, still an underlying issue then, i thought it was supposed to but i'd only had the car a month before it stopped.
I have no warning messages, and no lights on and vcds shows nothing in relation to the suspension or lights.
The MMI actually says "Adaptive Air Suspenstion - Sport" which is where i'm getting sport from.
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
