heres the install / remove datasheet -
http://elsaweb.spaghetticoder.org/do...-KO/20840276/2
If the motor is heard to be working then its probably the geared cable inside the mast or the cog at the bottom (unless the telescopes are rusted down)
You may get it working if you take it out and work on it but they are fairly simple things that if they have rusted up or got jammed it might be easier to speak to A8 parts and see if they have a working one to swap
