Old 15th December 2012, 05:55 AM
3.7 slp 3.7 slp is offline
The button in the B pillar and the remote use an electric actuator to release the boot - if it works on the remote (push and hold for several seconds) I'd be pulling the switch and testing the connections to see if there's a continuity fault. If not, it suggests the switch itself is faulty.
Cool thank you will give that a check over..it a new button as the old one feel apart a few months ago...the button dose light up.... but will take it apart and check it.
Is there anything else that i should check out
