Step 1 .....
Remove the lower trim below the headlamp by removing the screw as indicated.....
Gently pry/pull the trim out from under the Headlamp ...
Take care with the rubber moulding around the trim.
This moulding has securing points as indicated, located below the lower corner of the indicator lens.
My rubber moulding has perished and needs to be replaced.
Step 2 .....
Remove the 4 mounting screws/bolts as indicated.... 2 below the Headlamp/2 on top ....
Step 3 .....
The entire Headlamp unit can now be removed from it's housing .....
TIP: .... Loosen off the Hex Bolt as indicated (alongside the Hydraulic Fluid reservoir) .....
Once loosened the upper Headlamp mounting bracket can be lifted slightly to make the removal
of the Headlamp unit easier ....
Once the Headlamp unit is removed from the body disconnect the main wiring harness and
remove the Indicator bulb socket by turning anti-clockwise.
The entire Headlamp unit can now be removed from the body......
2002 S8 D2 F/L
