Old 1st February 2013, 09:10 AM
Very odd. This morning I indulged my cruise stalk with some serious "substance abuse" - well loads of WD40 and a good thrashing.
It then started working perfectly! Drove a couple of miles and every function worked as it should (except possibly the "resume").
Stopped briefly (delivering some stuff) and got back in the car, tried it when I could and it seemed to set, but then I tried to increase speed with the slider and it dropped out. After that it wouldn't work at all.
No opportunity to stop the car before getting home in case the system needed some sort of reset. More abuse and testing as and when I can.
Edit: been out again (looking at that RS4 http://forum.a8parts.co.uk/showthread.php?t=5963 ) and it's working again.
But the "increase" slider is intermittent and when it stops doing what it should it fails totally until ignition off/on. And the "resume" never seems to work.
Meanwhile any thought from anyone on on these 2 questions:
1. Is anyone aware of the system needing a reset of any sort after a glitch?
2. As I asked (maybe not obviously) earlier in this thread, is there any way of taking apart the switch section without taking it off the car? There are no obvious screws so I'd guess there are covers that can be levered off, or is it all glued?
Has anyone taken one of these off and investigated the faulty one to see what's wrong inside? I would given the chance - anyone want to send me a faulty one?
