Down pipes from the manifold. Well obvious would be second hand parts give A8Parts a call and do it yourself if possible, ATS and the likes might be able to source pattern parts but get a quote first if that's the way you choose to go, as it could be time consuming. The flange nuts / bolts from down pipes to cats get hot, cold, hot,wet ect and rot, and flanges to the cats.
Manifold to downpipe is not too bad, inner arch out for access. It might be as cheep to use a local specialist exhaust that can bend some stainless tube to suit.
