Old 25th February 2013, 02:05 PM
not sure if it's standard behavior on the later boxes with "s" sports mode but certainly not with a normal tiptronic box. Mine doesn't activate or light up the buttons on the steering wheel until you slide the gear selector across to the Tiptronic side
Yes, all Audis with 'S' boxes will jump into tiptronic if you touch the steering wheel buttons / paddles....
Pre 'S' boxes with 432 etc will need to manually moved to tiptronic mode before steering wheel buttons will work
