Originally Posted by The_Laird
Well, I took your advice and bought the blades from TPS. £28.56 including VAT - and they do seem much better (but yet to put them to the test).
BUT - I expected the passenger side to be shorter. Can anyone check the part numbers for me?
S 4BO 955 425 (with aerofoil or whatever it;s called)
4AO 955 425B
Thanks
I can't check the numbers for you Jim, but at that price you had to buy the whole assembaly (with aerofoil), now you have the OEM blades next time you need to change them you can replace just the rubbers at around £8
In this photo you can see one of the metal strips that hold the rubber in place, (there is one each side), you remove these and side rubber out as in second photo.
