From memory you might struggle to get 20 x 10 wheels on the fronts due to impeding the suspension members, take a look at Audipages HERE for some advice. The widest Ive seen at the front is 275's on a 9 inch wheel so 10 inch is a huge increase, may be a suck it and see job so try bolting the wheel on before you buy the front tyres! Rears can go much wider, my rears are 295 25 21 on 10.5 inch wheels whereas the fronts are 255 30 21 on a 9 inch wheel.
The final editions are 9 inch wheels and Ive got 275's on mine all around when I put them on but if youre lowering the front down like I have on coilovers then be prepared for some adjusting or put up with some rubbing!
