Old 2nd April 2013, 08:03 AM
Lol if he has the journey the centrecaps would have had through the forum member base is as follows.
IT>Singh>RanjA8>Architex_Ma8tey>Dezzy
It's been a whie now but i have been busy getting sacked.... however the boy and Neil did a deal at ADI last year and i now have a set of 4 caps and refer'b them black. I used a can of black spray paint they're quite awkward to paint because of the recess, i did have photo's but phone got wet and now don't have photot's (also lost the photo's of hitting 200k)
And the bad news is, they arrived today and don't fit.
Well, not without a bit of "bodging", though at £3 each I'm happy to do that.
For reference the part number is 4BO 601 165 A and the problem is the outer locating ring on the back, with the semicircular indents at various places around its perimeter.
You can't tell from the pictures online but it's actually a bit larger and differently shaped than the correct Avus centre, so needs a bit of sanding down to fit - I haven't done that yet.
What's more the genuine one has a ring with 12 bevelled ridges on its outside that actually make the contact with the alloy (plus the central spring connector which really holds it in place). The alternative one has a slightly larger ring with no external ridges and straight sides, so the whole perimeter needs sanding down to make it bevelled to fit the alloy.
You can see what I mean if you look very carefully at these 2 pictures, the 895... has small slopy "buttresses" outside the large ring, the 4DO has them on the inside:
(Either that or I'll just cut segments out of the ring, it doesn't do much really, just stabilise the edge. )
My wheels are replica's and the caps are genuine, i had to cut the little buttresses on the cap down so they would fit flush to the wheel.
