Thread: New mota
Old 2nd April 2013, 08:38 AM
My only dislike about the lighting at the moment is the non oem blue bulbs up front, but not bothered enough to spend 10 mins changing them
Do you mean the main beams?
I had one fail; and bought some (many years ago now) that were whiter/brighter to try to better match the Xenon's and was reasonably happy with that.
Since then bulb technology has improved so you'd probably have a wider choice and get something brighter too as they're a bit feeble.
Not sure on 10 minutes though, you need to take the ballasts off the back and probably remove the air filter box in its entirety too to get at the things.
The guy I bought it from set the lights up very non-standard, which I reverted. He had realigned the Xenons upwards (a lot) to act as a main beam and used the foglights (which not everyone will know are in the main cluster) as his dipped beams.
