Old 3rd April 2013, 06:34 PM
Mic has always sat Passenger side. .............
Behind A pillar is easiest.............
Looking again the mic can't actually be swapped with the electrical connectors, so nearside it is.
I'm thinking of using the same route I used on my focus for some auto-dim mirror wiring, basically around the edge of the windscreen then between the main dashboard moulding and the A-pillar trim and down near the door.
A thin cable can be tucked away there invisibly and quickly and if it's on the nearside can go straight into the glovebox to the bluetooth unit.
Yes, Ian, I know you wouldn't do that.
