View Single Post
Old 7th April 2013, 03:55 PM
Originally Posted by RanjS8 View Post
I checked the brake fluid reservoir today and yes the fluid had gone down.....not sure where it has gone at this stage but I m sure there must be a leak somewhere.....will investigate towards the end of week and update the thread accordingly.....
The reservoir is split - So were both sides low, or just one ? I guess if its only one side low then a leak is more plausible. If both are low then maybe the pads have all worn evenly and just enough fluid drop to activate the sensor.... Obviously the issue could be compounded if the car isnt parked on a the flat as the fluid will slop making the problem better or worse ..
Do let us know the outcome, I'm quite curious
