Old 9th April 2013, 11:25 AM
shropyfella shropyfella is offline
Thanks for the response guys. Just a couple of questions, do the codes indicate which MAF, boost sensor and manifold is the problem or is it sensible to change out both sides when a problem arises?
The manifold actuators seem to move freely enough by hand when the engine is off but I've read in a thread somewhere that you can cycle them with vagcom to check if the electrical connections are ok, anybody know how you do that?
