Old 14th April 2013, 01:48 PM
Disc is probably jammed part in, part out. Had that with a CD changer failing to eject a disc and had to manually take the unit apart to get it out. Once removed it went back in fine - think it was the label on it that was causing problems.
If the disc is knackered I've got 2013 discs for the RNS-D that are known to work
Adrian
