Old 17th April 2013, 07:16 PM
Hey Ranj,
I have this same issue. The SAIs are at the back of each head and add air to the exhaust flow to help warm up the cats at the time of engine start. Failure can be due to secondary air pump or the injectors on each head. With both showing, I'd start with the pump. If the pump is fine the remove and wash out the injectors in v hot soapy water (not a degreasant) and reafix. Its not terminal, but will shorten the cats life.
HtHs
