Originally Posted by RanjS8
You seem to be working along the right lines there Dezzy. But rather than try to charge the battery....I would just connect an external battery to that power point.....Surely that would give you the power to operate the central locking?....And then investigate the battery from there
I did connect to the underside but couldn't get power so went into the relay board, second from the left on and earthed to the door hinge. Probably just a bad connetion under, it's a little tight under to see properly.
I'm in the boot now, hopefully the battery will take a charge.
