I've tried a lot of ones telling me they won't give the fault but so far all do.
The ones in my car just now are fairly good, have a resistor loads in parallel and still throw the fault but I only need to turn the lights on manually and it goes away! Weird!
I've seen a VCDS coding where you can Code the side lights as LED or Resistance bulbs but not found a Code for the DLRs.
There will be a way......
