Thread: ecu location
Old 28th April 2013, 09:50 AM
You can do them via OBD, but only master ECU, then you have to move slave ECU to master port. You will end up with 2 ECUs that want to be masters which then need to be adapted correctly so that one is master and other one slave otherwise it will be running only 4 cylinders. I have not done any myself but I know that people, even professional tuners have run into this issue and some even ended up with bricked ECUs and forked out for 2 new ECUs from dealer.
If I had 4.2TDI I would definitely remap it but I would invest in BDM just in case, it's not all that expensive comparing to the value of car or 2 new ECUs. You can always sell it on later or keep as backup for any future jobs.
