Old 28th May 2013, 05:33 PM
I had worse than that on non-OEM brake pads, recommended and fitted by a very well-known independent in my part of the world.
This was on my PF S8 where the front pads have 2 pads each side of the disc on maybe a single backing plate, so 8 smaller pads of material in total at the front.
I had one of the two inner pads come away from the backing plate on each side, so it wasn't visible to a quick inexperienced inspection but braking was relatively poor. Even worse the garage didn't spot it at first either when I asked for the brakes to be checked. First thing they did was say the master cylinder was leaking and needed replacing, something I can't prove either way now but paid for!
So I was braking using two outer pads and one inner on each side at the front. It was "balanced" but obviously not as effective as it should be.
Replaced them with branded Audi pads eventually, which I paid for (no refund on the failed ones they supplied).
Never did resolve things satisfactorily with the garage, so I haven't taken my business there since.
