He meant corrosion to the body around windscreen, not the trim itself. Most of the quick and cheap windscreen fitters does not use proper primers and adhesives to save on time and cost and just use cheap primerless one component adhesive. This can result in corrosion if paintwork under glue was damaged removing old windscreen.
