Old 3rd June 2013, 09:27 AM
Some of my trim has cleaned up quite well with Autosol - around the doors and boot.
The possible leak in the vacuum system could well be the rubber seal on the boot actuator itself. Mine went. I replaced it with one from A8 Parts. Pretty easy to do. And you can confirm if this is the fault with the boot trim removed - you can hear it leaking. I'll post a photo if that helps, but I think there's a thread of mine on this somewhere - I'll have a look.
