Old 6th June 2013, 03:23 PM
ulfilias ulfilias is offline
Hi Amar
I did say :
It's a cat C or D iirc from before buying, rear end and while almost everything is perfect, there is a slight dip in the lower panel between the rear arch and passenger door. You need to know it is there, but...
So I knew about that. To my knowledge it is on the origional gearbox. I haven't done anything with it since owning and it has always seemed fine.
engine chain lifters (also did belts/chains)
The cam belt and even chains had been changed about 20-30K prior to this from what I recall, so i'd guess at 160ish. There was plenty of life left in them, but since the engine was apart an extra £100ish seemed logical sense to bring them fully up to life. I have the part worn belt though when quite anyone would use it I don't know, but i'm a bit of a hoarder. I have the origional audi cd & changer and a few odd bits too!
