Originally Posted by Adrian E
Worth considering S4 rims too - pretty sure they're identical but with an offset that spaces them a little wider than standard
Will double check the specs but might widen the search a bit for you
that's a good shout
don't mind if they are subtly different, what's most important is to get some Audi OEM alloys on the car - as have confirmed the 19's on mine are Italian something or other but definitely no Audi P/N and there's 2 wheels with bad flatspots on the inner rim.
plus moving to 18's means over £100 saved on a set of tyres which I also need to do.
